I pretty much am just writing this because getting permit inspections is apparently rather stressful, your results may vary.
Here's my problem. Since buying my home which was built in 1917, I've been aware that I really should pretty much bulldoze the whole thing and start over, but that practical constraints require that I instead rebuild the house a piece at a time. As such, I'm on my second electrical permit. Doing the work myself a section at a time.
The first permit covered the truly dangerous electrical that was at a level that it was amazing the house hadn't already burnt down. This was rewiring the second floor bedrooms and kitchen with new circuits on a new subpanel (later to be converted to the main panel) plus adding smoke detectors, and a few peripheral things. Along with this I just plain cut all power to the garage.
For this, I passed rough inspection on the 4th try. Each failed inspection, the inspector raised issues he could have seen at the previous inspection if he had gone beyond the first 2 or 3 errors he found.
Now I'm working on my second permit to move the service entrance, upgrade to 200A service and run the feeder to a new subpanel in the detatched garage. Tommorrow is inspection #3. Again, the errors noted on inspection 2 could have been noted on inspection #1.
Here's my problem: I don't mind being held to code, but when I get told that something is wrong, I don't mind fixing it - but I'd like to be able to fix it once. By the time I am ready for inspection #3, I will have had to make my service entrance and garage feeder connections 3 times. Working with heavy cable is a pain in the neck - both trying to get it through conduit (even if it's a short run) and trying to get it into its respective breaker.
What I'd like is if the inspector could look at everything, go at a slow enough pace I can write everything down, then make sure I understand what needs to be done to make it right so next time it will pass.
Without that, I'm starting to question the wisdom of following the inspection process. Alternately, I can understand why people might be disinclined to do anything about deficient wiring
Wiring like what is pictured below is what I'm replacing, and for whatever flaws my work might have, it is a thousand times better. In red circles I've noted flaws... The obvious flaw is the pervasive use of lamp cord. Wires are spliced outside junction boxes with tape laying against the wall. The wires go through knockouts in metal junction boxes unprotected. Wires dangle loosely. There are no covers on switches or receptacles.
Wires are stapled. No really. STAPLED. Maybe with a staple gun, but they look like paper staples really.
In one of the photos you'll see a brown wire hanging down in front of some lamp cord that has been painted with the wall. This wire was draping down from the ceiling where it ran to a flourescent light. I pulled it down because it kept knocking off my glasses, it hung down so low.
There is one green circle. That's part of my work to wire a new outlet for the GDO. Previously, the GDO was plugged into an extension cord draped over joists with its ground blade pulled out so it could plug into one of the receptacles that has no ground, is wired with lamp cord.
Anyway, here's the pics:
