I have added a small lean to shed beside the garage an installed it coming out under the eaves and was wanting to know the best way to get the area up under eave sealed or flashed to keep blowing rain from causing trouble.It's a pretty tight area an a sharp angle..
Any info is appreciated
Haven't flashed it yet nor roofed it..you mean like maybe install wood to close it off horizontally/long ways at the end of eaves where gutter is screwed to on garage ,an put flashing at bottom?.an close off ends so pests can't get in .
Thanks
Post a picture so we can see what your seeing.
Need to know at least what type siding you have, what type roofing your installing.
Reactions: jlhaslip
