1 - 2 of 2 Posts
I am refinishing my basement. when boarding 2 of the corners my studs were a little off I ended up shaving the drywall in the corner but produced an uneven and somewhat large gap (inside corners). can i simply fill the gap with mud and paper tape as usual or would you recommend using an inside corner bead? thanks in advance
Drywall contractor
Hard to say without seeing. A metal reinforced paper bead may be your best bet to be safe. You can pre-fill with setting compound, flat tape the gap, then angle tape with paper.....
1 - 2 of 2 Posts
