1 - 2 of 2 Posts
We have an older Inglis fridge...top freezer works great. Over the last while we noticed the fridge becoming less cold, now its almost not cooling and we took everything out. With that there has increasingly been water pooling on the bottom of the fridge, enough to keep a towel on the inside to soak it up. Where do I start to find a fix - Thanks in advance.​
#1 HAWKEYE FAN
check the evap coil in the freezer, it may be frosted over. If so you have a defrost problem and need to find the defective part.
1 - 2 of 2 Posts
