I am not sure I understand what the point would be? What is it you are trying to accomplish?
If it is your goal to use an indoor temp from another room rather than the temp at the stat location, you can use a simple remote temperature sensor wired back to the stat.
If you want to be able to adjust the set temp in another room, I would just move the main stat to that location.
If you want the Remote Room Sensor SYSTXCCRRS01 to work in parallel with your main stat (either non-zoned or zoned), I would guess that would not work, but I am not sure.
Again, what is your goal and which main stat do you have, the zoned or non-zoned version?
