I am coming to this forum to get some help on a strange problem of my furnace.
Furnace stopped working the other day, it is a HEIL H8MPT100F14B1 two stage gas furnace, built in 2006.
Inducer motor simply does not start.:vs_mad:
Circuit board blinks three flashes, code is Low Pressure Switch open when should be closed.
first changed both pressure switches, same problem;
second, suspected relays, got new circuit board, connected everything exactly the same as before, still the same three blinks.
With multi-meter, measured W and C, 27V AC, so no problem for thermostat or thermostat wiring;
measured C and R, 27V, so transformer is working;
measured 115V output port for the inducer motor, found no voltage at all.:vs_mad:
What could be the problem? I have brand new board and pressure switches.
