I am looking to install a post with 120V power outlets on it - in my yard. This will power a water fountain, two low voltage lighting transformers, and the occational power yard tool.
I understand the trenching and electric connection from a nearby building to the post - that's not where I am looking for info/suggestions - rather it's the actual outlets on the post itself. Here is what I am thinking, please toss out your thoughts and suggestions.
In-use recept cover such as this: http://www.mulberrymetal.com/MulberryBrochure.pdf
Thanks!
Vince
- 4x4 treated post - 2' in the ground, 2' out of the ground - set in concrete.
- Conduit exits the ground and goes up the post to outdoor single box #1 with duplex recept, then another short piece of conduit to outdoor single box #2 containing a dusk to down photo sensor, and yet another short piece of conduit to box #3 contain a duplex recept (switched by the photo sensor)
- Each outdoor single box with duplex recept has a in-use weather cover
- The low voltage lighting transformers are attached to the 4x4 post and plug into the photo sensor switched recepts - the fountain and the occational yard tool plug into the other (unswitched) recepts
Thanks!
Vince
