Hello,
My first post here, I hope I don't look too stupid... I have a TV on the wall, and a surge protector near the floor, and I'd like to hide the wires (common problem, I guess).
I know I can't run the actual power cord inside the wall. I've been searching around and found these kits with an inlet and an outlet, and I thought they would save my day. But they are expensive as hell and I'm not a big fan of a NEMA 5-15P on my wall, even being recessed - although I could live with it if it were less expensive.
My next plan is to build my own "kit" using an IEC 320 male (receptacle) instead, that I can connect to the surge protector using a standard computer power cord. So two boxes, one IEC 320 on one side, one common outlet on the other side, romex connecting both. I would have to buy a blind plate and cut an opening for the IEC 320. Does that sound like a good plan? Is there anything against code in that? It would be a lot cheaper, and I already have most materials around. Just need to buy the rework-type boxes.
Thanks in advance,
VMat
Thanks in advance,
VMat
