1 - 6 of 6 Posts
I ended up buying an Ideal 61-164 circuit tester. It was more than I wanted to spend but it found a bootleg ground with little effort (since remedied).
But you know how it is, to a man with a hammer the world is a nail. I've been doing all the tests. I have a 20 amp/12 gauge circuit that is showing a .33 ohm hot impedance (limit is supposedly .25). I am going to do the best job I can on this place. The other instances I've found turned out to be old wire nuts that weren't making a good connection. I haven't torn into the wall but this wire appears to run directly from the panel to the outlet I'm testing. I temporarily ran a piece of 12 ga. wire from the panel to where the outlet is, 38-40 feet. It still reads .30 ohms of impedance on the hot. Where am I thinking wrong here? Is that too long of a run (doesn't seem plausible) or is .25 ohms impedance on the hot not a serious limit? How much is too much.
I'm also not sure how seriously to take the values shown on the tester. With my test setup I show .30 ohms impedance on the hot but only .08 on the neutral. Seems like they would be the same if everything was working...
What do other circuits test?
Close to the panel - .22 or so. As you get farther away it goes up to .36 or so with a couple of outliers at about .45.
But this is the only one I've tackled. It's one of the few wires that I can actually see from the panel to the first outlet.
I see that the .25 seems to be something from the NEC that is not enforced. I was just curious what number would alarm folks. The video sure makes it sound like 1.0 ohms is the cutoff...
1 - 6 of 6 Posts
