I just read a lengthy report on impact resistance of doors and windows in hurricane areas. Turns out that the current test is not too useful for predicting performance of door and window sacrificial shutter systems in real world events. The report does indicate that steel shutters perform reasonably well in reducing the potential for breakage of glass due to missile strike in a hurricane.
So far as I can tell, there are no glass doors made that are sufficiently impact resistant to survive a hurricane, they all require shutters to be effective. But then again, I don't know if you are designing for hurricanes. There are numerous shutter system available, some on tracks, some mounted directly to the door or window frame. Google steel shutter system and you will find lots of alternatives, but you may want to check with the local building authority to discuss what they have found works best in your area.
