1 - 6 of 6 Posts
· CareBear
I looked at the NEC 2014 draft, section 200.6 and it says that grounded conductors should have either a gray or white finish. Yet all over the Internet it says ground wires are green, plus ground screws for appliances are green.
· Licensed Electrical Cont.
This is one of the reasons why lay people should not simply pick up the NEC and start reading. You need some primer to get a feel for it first.
Some serious mistakes can be make otherwise.
· Resi EC
There are 3 grounds used in electrical work.
Ground - Earth
Grounded - Neutral, White or grey in color
Grounding - Conductor, Bare or green in color
In most transformers or main disconnecting means the Grounding takes the Grounded to Ground.
· CareBear
Most of the NEC is understandable, and I have some clue about electricity, so I'm not entirely lost reading the NEC. Gotta start somewhere, and the Sunset diy electrical book doesn't seem to be it.
· Banned
*Cough* Mike Holt website. I have found the Black & Decker Complete home wiring guide to be the best. Also if you can still find it out on the web, the U.S. Army basic electrical manual is good.
I may have it in my box.com account, or on my pocket drive.
1 - 6 of 6 Posts
