...and I think it did --- is there any hope for it -- or...
Here is my story -- sad, but true...
And I'm not gonna lie about my mistakes -- I know I made them now.
But I'm a city boy now living in the country. And I am on a steep learning curve...
I have an Echo 352 Chainsaw.
I've used it, over the last 2-3 years -- 5-10 times or so at most. And never a particularly difficult or aggressive use -- small trees and such.
I have been using it with gasoline that I got at the local gas station.
* I know - BIG mistake #1
I have been using this oil: Pro-Select Premium Bar & Chain Oil
Up until the last 2 or 3 times I used it -- when I finally purchased:
Power Care 50:1 High Performance 2 Cycle Fuel - Ready to use Pre-Mix Gas Plus Oil - 92 Octane
I did not drain the gas tank before mixing the 2. But - I used it a couple times and it worked once using the right stuff.
Which brings me to last week:
I start the saw - I'm cutting small limbs -- and the chain comes off.
I shut down -- open it up - reinstall the chain.
I pull and pull and pull -- cannot get it to start.
** I flooded the engine - that much I am 98% sure of.
So I leave it for a while -- try again. There is some smoke -- smells like something is burning --- so I stop completely. Put it on the shelf.
Couple days later -- I open up a couple pieces -- give it a good cleaning with rags and q-tips. Close it all back up.
I hold the trigger and squeeze it --- this time, starting it properly for sure -- having read a bit and watched some videos -- knowing I obviously have been making lots of mistakes along the way.
I get it to start -- but it does not sound great. More smoke. And it dies.
I check the gas and oil - both have plenty in them.
Then -- I try again. Cannot pull the cord at all. Cannot move - not even budge, the chain lock.
I head over to Home Depot -- but the tech is off on Sunday. I ask if anyone there knows a lot about this stuff and speak to Arturo.
He takes a good look - pull off the spark plug -- says it is completely dry --- asks me some Qs I could not answer until I looked at home. But tells me he is relatively sure the motor seized.
Personally - it looked like there is a little potential scorching - but I have no point of reference.
So unless and until I bring it to someone -- I am wondering, is this the end of the road and time to lick my wounds and chalk it up to experience and buy something new?
Or can I save this guy?
Thanks in advance.
Thanks in advance.
