Do you have a question or are you trying to correct a mess?
I'm just guessing the subpanels are not wired correctly and that there shouldn't be two extra 240v cables jammed into the top of the main breaker. That's all I'm really interested in. I won't be working on it. Just want to inform the owner why they're not set up correctly. Would like to tell them how to correct the mess.Do you have a question or are you trying to correct a mess?
You are quite correct !there shouldn't be two extra 240v cables jammed into the top of the main breaker.
Wouldn't bet my life on it, but don't remember there being any more empty slots, but maybe you're saying 'it looks like there's only one' because the number of slots is always balanced (same number of slots on both right and left bank)? Haven't measured the package unit amp draw yet, but my experience in this park is usual load of 11-15A on similar units. Just had a 29-yr. old package unit amp draw of 15+ amps. Data plate RLA amps was 17.9You are quite correct !
Depending on the size of the load
from the sub panels, you could feed them
thru breakers off the existing panel.
How many spare slots ?
it looks like only one ?
It is for an air-conditioner/mobile home, and I assume you're saying "there shouldn't be a neutral" because it just isn't needed.Looks like a disconnect for an air conditioner on a MH. If so, there shouldn't be a neutral, just a ground.
Tried to edit my post #10, but edit time expired, so editing here. The neutral white wire leaving the subpanel would be connected to the package unit cabinet, but the neutral (used as a ground wire) should've been connected to a ground bus bar mounted to the subpanel box, correct?It is for an air-conditioner/mobile home, and I assume you're saying "there shouldn't be a neutral" because it just isn't needed.
This subpanel/disconnect (pic) is indeed for the package unit. Since there is no grounding in this pic, the package unit cabinet is not grounded, correct? Once had a compressor wire fall off its comp. terminal while running. Hit the cabinet and kicked breaker off. If that cabinet had not been grounded, and wire remained in contact with the cabinet, not a good situation I'm thinking, yepper?... just like this ungrounded cabinet situation maybe.
What are the possible consequences of the extra two 240v circuits jammed into the main breaker top?
Good to know, but not good to hear! I'm getting into the habit of using a non-contact voltage detector when walking up to a cabinet (Yuri pointed out this risk a while back). You have a better way?Green tape should be put on the white wire on both ends. And connected to the ground bar in the main panel. .... because the neutral bar might be too busy with normal operation of branch circuits, and the ground circuits will not be... correct? This is the same reasoning behind the change from 3-wire dryer cables to 4-wire, correct?
A package unit that is not grounded. Can electrocute you if a line wire were to short to the package unit case/frame. Or if the compressor or condenser fan motor windings short to frame.
There have been a couple HVAC techs killed that way.
Depends on the actual service size. I'll let the electricians go into a better explanation then that.Good to know, but not good to hear! I'm getting into the habit of using a non-contact voltage detector when walking up to a cabinet. You have a better way?
Thats about the best way to see if its safe to touch a unit.
What causes a motor winding to short to the motor frame? Besides age and overheating?
Thats about it. A weak cap can cause a motor to run hot.
What are the possible consequences of the extra two 240v circuits jammed into the main breaker?
Issues like over-amping circuits/damaging equipment?The lugs are made for one wire. Stuffing multiple conductors in the lug can lead to over-tightening, hot spots or loose connections. All of these can lead to issues including fires.
1 - The enamel insulation on the coils can breakdown causing shorts to frame, this can be made worse by enviroment conditions.Good to know, but not good to hear! I'm getting into the habit of using a non-contact voltage detector when walking up to a cabinet (Yuri pointed out this risk a while back). You have a better way?
