Hi,
There used to be wallpaper along the bottom of this wall with wall paneling on top. Should I install wainscoting? I feel like if I do it's going to bulge out and be an eyesore, plus I would have to retrim everything I think (to match the thickness). The thickness or the trim is pretty small.
Other options are paint or wallpaper. If I paint,
- Should I paint both the top and bottom white/neutral?
- Do I need to use an oil-based primer, since I know wood leaks yellow?
Do you guys have any suggestions or ideas? Have never worked with wainscoting before fyi.
Thanks for your response,
Mike
Mike
