I recently replaced a hot water tank in my home who's TPR pipe was never vented properly from the day I bought the place. The TPR drain just went down and into the crawlspace.
I've since replaced the HWT, and installed a expansion tank and drain pan in the same location which is located in a coat closet off the living room. There is no easy access to an exterior wall for the TPR valve or the drip pan drain to go.
What can I do in a situation like this???
The one idea I have is to install a 2" or greater floor drain in the closet which would tie into the houses main discharge pipe in the crawl space (via a p-trap obviously). I could then route the TPR and drip pan pipe into the floor drain.
Is this making sense?
Is that legal?
From what I understand, the important thing is; unless they drain to the outside, the discharge pipes from the tank have to have an air-gap before going into a floor.
again, I do not have easy access to an exterior wall from this current location but in the DWV lines in the crawlspace are close by.
Is that legal?
