1 - 14 of 14 Posts
I've got plans to re-do my whole fireplace this summer, its covered in wood and I want to do drywall. Anyway, its above my fireplace, which itself is about 8" from the ground, if I were to mount the TV today it would be just above eye level (its 42"), which means if you were sitting on the couch you'd be looking up at it quite a bit. Should I lower my fireplace down to the floor to get the TV lower? What would YOU do?
Also, what are your thoughts on recessing the screen into the wall, or building a mantle out from the wall to hold it, i.e. attached picture. Besides beings more trouble, is it worth it, any disadvantages?
Ideally, you want your eyes to be somewhere between the middle of the screen and 1/3 of the way from the bottom of the screen. Sitting on a couch, this would put the middle of the screen somewhere around 40-50" off the ground. Of course, the more reclined that you sit, the higher of an angle your eyes will look at the screen, and the higher it can be. Having it mounted above the fireplace is not ideal, but lots of people have it that way. It seems to me that ripping out the stone at the bottom of the fireplace, as well as physically lowering the fireplace is alot of work. If you were not planning on doing it, I wouldn't. If it's coming out anyways, then you may as well lower it. By just stripping off the wood trim, you should still be able to lower it a bit.
As for the picture frame, I wouldn't. Even though it will look nice, it will kill your ability to easily upgrade your TV in a couple of years if you choose to do so. If it is a nice big flat wall, you should be able to fit about 60" up there without it looking out of place (and move the 42" to the bedroom or bathroom or something :thumbup:).
· JOATMON
Well...if you catch me sitting on the couch....I'm not exactly sitting up.
Our TV is also above the fireplace...but I also have it on a bracket that lets me tilt is to that it's at the proper angle.
I personally prefer it up high....that way it's not blocked as easy by people walking by. It also means you can have a couple of chairs in front of the couch and the peoples heads are not blocking the view.....
And if you have kids....it also means you can keep their hands away from it.....
· Bill Kearney
NO. Do not put the TV over the fireplace.
It's very uncomfortable to be sitting on a couch that close and having to crane your neck back to see the screen. The only time a set mounted that high has an use is for a large space where you need others across the room to be able to see over the heads of seated people. Like in a bar. Not for typical residential TV watching.
There are strong arguments against having a fireplace anyway. They're basically pointless in modern houses. They end up being just a place that wastes heat. Putting a TV on top of it just makes a bad idea, worse.
· JOATMON
Hmmm.....wow.....I guess the couch would have to be really close to crane your neck.....
Funny....I sit on my couch and I just have to look up a little....I just use my eyes.....I don't have to 'crane' my neck...
And if I decide to be really lazy and lean my head onto the back of the couch....it means it's a lot easier to see the tv.
I've had both setups.....tv at around 40" off the floor....and currently with it above the fireplace....I'll take the fireplace any day.
Oh....one thing about heat....there is a mantle between the fireplace and TV....most of the heat radiates out.....the tv is not bothered....
1 - 14 of 14 Posts
