1 - 9 of 9 Posts
Hullo to everyone.
I have a split unit air condition and when the compressor is working for some time I see ice (frost) on my tube on the outside unit (it is the thick coil). Does this mean that I am short of Freon (Refrigerant)?
· In Loving Memory
Or you indoor coil is dirty, or your air filter needs changed.
Plus a couple other possiblities.
· In Loving Memory
You need to check if your indoor coil is dirty first.
And then if it has a TXV or a fixed metering device.
If its just a dirty coil, just clean the coil.
1 - 9 of 9 Posts
