1 - 2 of 2 Posts
Just replaced the leaking water valve on my Whirlpool fridge. Figured everything was fine but the ice maker isn't working. Any suggestions? Water dispenser is fine but ice maker is not.
Also, as I was pushing my fridge back when the water supply line cracked and sprayed water everywhere. . Instead of having to replace the entire supply line can't I just buy a nut and a plastic ferrule? I would really don't want to spend $30 on the supply line when its just a small piece that ripped.
Sure, you can splice that line. but, if it's plastic you should change to copper. don't know what i/m setup you have, but if you search through posts, H/Wman has helped others with i/m problems. you'll have to see which type refers to yours.
1 - 2 of 2 Posts
