A lot of new homes built these days with 2 climate zones have the air handler for the upper floor located in the attic, so even with good ventilation, the attic will get warm when the furnace is turned on.Go back and add your location to your profile.
Storm and Ice Shield helps prevent Ice dams from doing damage to the home.
Without proper venting and insulation your going to have ice dams, and shorten the life of the shingles.
Yes,,,,and I probably will not answer the phone if I know they are wanting a new roof. :laughing:Has anyone installed ice and water shield that covers all their wood sheathing instead of felt?
not for the entire decking but for say the first couple squares at the drip edge when we got the new roof done. i have a huge thread in here about thisHas anyone installed ice and water shield that covers all their wood sheathing instead of felt?
After a roof has ice & water shield installed on all of the sheathing, why would the homeowner ever need a new roof? Maybe just new shingles. Thus, no new decking would ever be required.Yes,,,,and I probably will not answer the phone if I know they are wanting a new roof. :laughing:
And that is because the entire house will need to be redecked and the estimate for that will be astronomical. :whistling2:
The shingles normally fuse to the I/W and the I/W to the decking.After a roof has ice & water shield installed on all of the sheathing, why would the homeowner ever need a new roof? Maybe just new shingles. Thus, no new decking would ever be required.
Yes and we do not even get freezing temps here. A lot of it is custom homes and or PW jobs that have it spec'd.Has anyone installed ice and water shield that covers all their wood sheathing instead of felt?
Damaging hail.I roofed an apartment complex in STL that had 3 courses of Ice and Water and along the rakes.We replaced over 1000 sheets of plywood all containing the Ice and water and the top of the shingles because the tabs would pull.After a roof has ice & water shield installed on all of the sheathing, why would the homeowner ever need a new roof? Maybe just new shingles. Thus, no new decking would ever be required.
Why would the I&W shield bond with the shingles since the peel/sticky side contacts the sheathing. I didn't know the top side is sticky also.The shingles normally fuse to the I/W and the I/W to the decking.
Makes removal about impossible.
Removal is easier, faster, and probably more cost effective when it comes to pulling the whole roof deck up sheet by sheet.
They melt together. Plan on removing all the wood where it's been used. It only adds a few thousand extra to each job.Why would the I&W shield bond with the shingles since the peel/sticky side contacts the sheathing. I didn't know the top side is sticky also.
