I would say to use a handhold tile saw but that is going to be practically impossible to get close to the toe kick. So in your case you might be able to use a regular diamond grain hand cutter. What you will do is go over it until you are about 3/4 of the way through the tile and from there you should be able to snap a straight line... This is going to be a hard job
Just thought of it you could use a grinder with a small diamond blade on it as well and that should not kill you as much as a hand tool!!
On the hardi I would always say replace it, but depending on the damage you might need to.. if it is the concrete kind you might be able to roll with it.
