1 - 20 of 23 Posts
· Still going...
I did a little testing last night so I hope someone can explain if this is normal or I have a supply line that is installed incorrectly somewhere. I have lived on municipal water up until two years ago. SO trying to understand this.
I have an Aeromotor T series pump 12 gpm at well depth of 40 feet. Running well so its not the problem.
I have a Water Ace RPT 86 well pressure tank, whole house filtration, whole house iron filter (Fleck 7000 high flow) Whirlpool water softener, also whirlpool whole house charcoal filter. With every faucet in the house open in the middle (single control lever) or both wide open (two handle) the highest flow rate I can get is 7.7 gpm. If I by pass each filter I can gain about 2 gpm. However when I close the hot side or turn the single controls to cold the flow rate doesn't change. Shouldn't it go down at least by 20% to 40%? The rate also doesn't change much as the pressure drops form 60 psi to 40 psi when pump kicks on.
I was under the impression that if I upgraded the well pump I can get higher flow rates but now I don't think that is what is needed. The current well pump with everything wide open is able to almost refill the pressure tank although very slowly.
Adding a higher capacity pump will only speed the rate tank is re-filled not change the flow in the house, correct?
  1. What can I do to get a higher flow rate after the pressure tank?
  2. I had started increasing the pipe size from 3/4" to 1-1/4" but only have gotten to charcoal filter inlet side. Am I wasting my time?
  3. I have a tempering valve installed on the water heater, can this affect flow rate?
  4. Adding another pressure tank will only increase supply of water available before pumps turns on?
  5. I am finding errors with every project have done in this house is there any known errors that could have been done I should look for? Loops? Hot/Cold connected together somewhere? So now I am wondering...
Any help would be appreciated.
Are you sure the well can deliver (or still delivers) 12 gallons per minute continuously?
You may need a storage tank as well as a pressure tank.
The storage tank allows the pump to deliver a trickle over a long period of time, say, overnight and then you have enough water to use during the day.
If you put a booster pump in, you need another pressure tank after the booster pump.
· Still going...
Are these storage tanks different than pressure tanks, i.e. no bladder?
So this would get installed after pressure tank: check valve, storage then booster or check valve, booster then storage? Can all this go after my water treatment but before water heater?
Sent from my Samsung Vibrant using Android DIY Chatroom
What does the pressure gage at the pressure tank tee show when you have all flowing--is it maintaining at least the low side of your pump switch settings (typically 30/50 or 40/60)?
If the pressure at the pressure tank under flow is all right I would suspect a restriction at a common point in the plumbing between the outlet on the pressure tank and the first filter.
· Still going...
Discussion Starter · #6 · (Edited)
As soon as pressure drops to 40 psi pump kicks on. Pressure slowly increases about 1 psi every 30-40 seconds. While running at 7.7 gpm.
AllanJ:
I am not sure if pump is putting out the 12 gpm. But I wouldn't be able to leave water treatment in bypass. With all bypassed seems pretty close to 10.5-11 gpm. I'm thinking fancy shower isn't going to happen... :confused1: Most single tanks I've found will draw down in 60 seconds with this shower.
· Water Treatment
The more equipment that you have in the water line from the well to the end point with in the house the more the pressure loss and flow loss.
It is the nature of the game.
Just why are so many needed?
AllanJ:
With the capacity of your bladder tank you can compute the well pump output. In your example the pump is providing 7.7 gpm plus the amount that is gradually refilling the tank. For example if your pressure tank capacity with a 40/60 pressure setting is 3 gallons and it takes one minute for the pressure tank to go from 40 to 60 psi then the well pump is putting out 7.7 + 3 = 10.7 gpm.
Given what you are seeing I would suspect a restriction in the piping after the pressure tank. Do you have CPVC piping? The inside diameter of CPVC is smaller for any given nominal size than copper of PVC. With iron in your water the inside of the pipe may be fouled and reducing flow.
But in the overall scheme of things I think you are correct that a very large flow show head is not feasible with your existing well/well pump because with the very slow filling of the pressure tank with flow of 7.7 gpm I suspect your well pump is only delivering about 8 gpm.
I further suspect that when you bypass your treatment equipment that the pressure tank isn't filling at all and the pressure drops below 40 psi.
If your well recovery rate allows it you could put a larger pump in the well to get more water but you want to be sure not to exceed the well recovery rate--at all times of the year.
· Still going...
Discussion Starter · #9 · (Edited)
Source: Private Well
pH: 7
Iron: 2.8 PPM
Manganese: 0 PPM
Hardness: 667 PPM
Hardness: 39 Grains per Gallon
Total Dissolved Solids ('TDS"): 871 PPM
Tannin: 0
· Still going...
Discussion Starter · #10 · (Edited)
With the capacity of your bladder tank you can compute the well pump output. In your example...
...larger pump in the well to get more water but you want to be sure not to exceed the well recovery rate--at all times of the year.
I spent all day reconnecting the outside water spigots and installing the stand pipe. I was able to fill a 5 gallon bucket from closed to fully open while filling in under 15 seconds. Tee to outside lines are after iron filter.
· Water Treatment
pH: 7
Iron: 2.8 PPM
Manganese: 0 PPM
Hardness: 667 PPM
Tannin: 0
So that does not say why the large number of treatment units.
So there is just under 3.0 iron, and 39 grains of hardness....
Any smell?
Always use just the equipment needed and no more..
Are you saying you have replaced the piping from the pressure tank to the outside spigots? If so did you find blockage in the pipes?
· Still going...
Discussion Starter · #13 ·
I replaced the pipes in-between the iron filter and the softener. There was no blockage. My thoughts now are that the flow is restricted at the softener and charcoal filter. Both of these will need to be upgraded as they took on iron content before I purchased the iron filter. Can't imagine that would be so bad in only 18 months. Fleck 7000 filters are high flow. Currently have Whirlpool.
What I need to do is figure out how to get the Fleck 7000 meter to display gpm.
The Fleck 7000 will only display flow if it has a flow sensor--most filter versions of the valve don't.
As I understand your installation you have four filters installed. When you say you bypass a filter and get an increase in flow of 2 gpm are you bypassing 1 filter or all four filters?
Each filter and its associated valve/piping is going to cause a pressure drop and a resulting reduction in flow. Unless you have lots of silt or particulate matter in the water I don't see the need for the "whole hours filter" (is this a cartridge filter or a backwashing filter?) I also question the need for the "whole house carbon filter" with well water. If both of these filters are cartridge filters that could be a large part of your problem.
· Doing it myself
Question : Don't filter systems (IE water softeners, iron removal, ph balance, etc. etc. etc. . . . ) have an integral flow restriction device in them?
:wink:
I think they might even be right around 7 GPM.
Why do you NEED more than 7.7 gpm that you state that you are getting in your original post?
· Still going...
Discussion Starter · #16 · (Edited)
:wink:
The plan was to do one of these fancy multi-showerhead spa baths. This is beginning to go out of the window. Valve has 6 ports my flow would be tapped out at 3 and would lose flow/pressure afterward thus losing showering "experience."
The Fleck 7000 will only display flow if it has a flow sensor...
...need for the "whole house carbon filter" with well water. If both of these filters are cartridge filters that could be a large part of your problem.
I have recommended sediment (doesn't affect much), iron (now proven not to affect much, backwashes), water softener (possible culprit, backwashes), whole house charcoal filter (added culprit, backwashes). When I purchased iron filter I thought I had flow added on.
· Still going...
Discussion Starter · #17 ·
One thing I forgot, the run from water heater and from last water treatment is 60 feet to the faucet used most frequently. It's ran in 3/4" copper. Could this be creating too much head?
· Doing it myself
Depends on the flow rate out of your filter system. If you're only getting 7gpm out of the filters, you could run a 3" water line and still only be feeding the 3" line with 7gpm.
· Still going...
Discussion Starter · #19 ·
Will bypass both the softener and the whole house charcoal and see what I get. I can press the up and extra cycle button and it will display gpm. Accuracy isn't what I am after only looking for an increase vs. no change.
· Still going...
Discussion Starter · #20 ·
I did the Fleck 7000 flow test. With both the softener and charcoal filter running the flow by the iron filter was 9.0 gpm. The softener still displayed 7.8 to 8.0 gpm. After putting the softener on bypass the flow rate increased to 10.2 gpm on the iron filter.
Low an behold I bypass the whole house charcoal filter and the flow rate jumps to 12.2-12.5 gpm. Even more exciting was the pressure tank was able to start re-pressurizing at the 12.2 gpm flow rate.
I need to go ahead and get the reverse osmosis and remove/ replace the whole house charcoal filter. To do this right I need to get a new Fleck 7000 filter and softener.
As far as the luxury bath goes I have to see if I can design an experience around maybe 15 gpm and see if its worth that expense.
1 - 20 of 23 Posts
