1 - 14 of 14 Posts
Hi Folks,
I stained my deck last Saturday. I do it up right (third time, I know the drill, quite anal in the prep dept.) I thought I had 48 hr. window of clear sunny weather, but a sneak squall blew in Sunday morning turning my deck by sunny Monday into a splotchy brown and white mess. I used Olympic Honey Gold Toner. What should I do next? Deck's just 5 years old, wood in nice shape (from all that lovin' care given it.) Should I simply recoat? Or (egads, the work) strip off what's left of Saturday's stain? Then sand it down to naked wood? Sooo much work and $ went down tubes Saturday. Can a simple re-coat (prepping with nothing than a wash and blow vac and a tack cloth wipe for the re-coat) restore me to the deck gods' good graces? Can "two" coats exist side by side with "one" (the side where the rain washed off)? Help! I'm in deck limbo! Anybody else been there and found the way out? Thanks,
Woz
Don't worry, this has happened to the best of us.
Your best bet is to let the deck completely dry and then wash (a light scrub will help).
This should remove the white spots.
If your coating is still blotchy another coat of the Olympic will help make things uniform.
Don't worry about the first coat not working, once it hits the wood the protection starts.
Joel
Discussion Starter · #9 ·
Thanks for the encouragement!
Joel
Thanks. Makes me feel better. I took Mouse's suggestion, tried restaining a few sample places. It looked ok. There was some slightly blobby spots where the rain coagulated the stain - but no big deal. I don't think I need to strip the whole thing off, though. (This idea didn't thrill me as I thought that would be the remedy everybody would suggest.) But it seems another coat alone, after cleaning and getting whatever dust has blown on it will work. The fact that there are two coats in one place and one in others I think will be unnoticable. In a year, Mother Nature will strip it for me!
Woz
Discussion Starter · #11 ·
Well, with several days of fine weather in Richmond, VA I re-stained a deck that last week got major rained on the day after I stained it and afterwards looked like an old brown and tan baseball glove. I didn't know if what was left of the first application interspersed with bare wood would look really bad with a second coating. But it came out fine. I really didn't feel like scraping, but the Olympic Honey Gold Toner covered everthing adequately. In a couple places it's obvious that it's darker where the rain didn't get to - but overall, not bad, better than I expected. I could live with it. After all, it's just a deck! It will suffer from the slings and arrows of outrageous weather (but now a bit protected from the sun and rain for another year and then maybe I'll scrape or purge the old stain and start afresh.) Thanks for the advice.
Woz
· the Musigician
no problem Woz, i just wonder about the quality of the stain??
you did it one day, then the next morning it rained?
seems to me it should have been fine! did you brush/roll, then wipe it down?
DM
Discussion Starter · #13 ·
I have been using the same kind of stain now for the third time in six years, Olympic Toner. I've done it the same way each time (almost) and had the same good results the first two times. The difference this time was in the way that I applied it, spraying rather thickly. I had sprayed the whole deck in the past with good results. I was convinced by a guy at Lowe's that I should roll it, not spray it, to apply more than the spray delivers. When I got done with the spindles (so easy to spray), I thought - I'm just gonna keep on spraying and I probably applied it thicker than I had done so in the past. The other difference was - I started staining late in the afternoon because it took so long for the deck to dry from a wash to prep for stain. By 8 p.m. it was done (which I know isn't optimal, as it gets more humid in the evening - but I expected a dry day the next day.) Sunday morn I awoke to the beautiful sounds of sprinkling which turned into an all-day pounding rain. The 10 hour "dry" it had wasn't enough. It didn't help that it was thick, either. I may experiment with another stain next year. After doing some research, I'm more aware that all are not equal - as well as finding out about oxygen bleach as a wash.
The re-application was by brush. I now think that's the best way to get it on - the boards, at least. You can really work it in. From now on, I'll spray just the spindles. Thanks for asking, If you have any advice on stain, I'm all ears.
1 - 14 of 14 Posts
