OK, I laid a fairly large floor (Allure vinyl faux wood planking) and I really messed up. There is a section of about 3 planks that have multiple razor cuts in the surface. Yea...I didn't have a good base when I was cutting the flooring and some of it went through. Here's what I'd like to know: Can I possibly repair those spots with some vinyl seam sealer as opposed to trying to cut out the bad planks and replacing them? The cuts are very thin and with the planks being vinyl with the "wood" vinyl facing I was hoping that maybe a sealer would kind of meld the slits together and basically blend or hide them. The manufacturer recommended cutting out the damaged planks and replacing with new. The problem I have with that is the seams that would be created if the cuts are not perfectly precise. I could see the gaps being fairly ugly with me not being the artistic type.
I am an idiot looking for some help.:huh:
