1 - 7 of 7 Posts
I am remodeling my bathroom. I am getting ready to start tiling the floor and tub and shower surrounding walls. I will use 6x6 porcelain tiles on the floor and 6x6 ceramic tiles on walls.
I need to buy sanded or non-sanded grout and tile spacers.
What is the most common space between 6x6 tiles?
Thanks.
· Retired Moderator
Spacing is a matter of personal taste and the design of the tile---
A very square cut tile like granite usually looks best with a small space--1/16" is common
The more common rounded edge tiles often look best with 1/8 or even 3/16"--
I suggest that you lay out several tiles--space them so they look good to you---then measure the gap and see what you have----
As to grout----unsanded for 1/8" or smaller----sanded for any thing wider---Read the package.
-----Mike-----
Thanks Mike.
I did few home tiling projects before. I used different spaces, smaller and bigger. I found that in bigger spaces grout does not look very even. I always follow grouting instructions but I still can’t do it perfect. It looks fine from the distance, but if you check it from 1 ft or closer you will see that it looks uneven.
This is why this time I decided to go with smaller space. I got 1/8” spacers. I wanted to buy a non-sanded grout, but HD guy recommended me using sanded grout for 1/8” spaces because it does not shrink.
· Retired Moderator
Not a bad plan----Let's see what Jazz or Bud have to say----Spacers? Check out the round ones from Lowes---They are much easier to use and remove than crosses.----Mike----
· Tileguy
The information you have so far is all good. Go for it!:)
I will add that; how close you can space the tiles will also depend on the quality of the tiles...meaning if they aren't cut perfectly square they won't be easy to put close together and maintain straight grout lines.:)
· Tileguy
Don't depend on spacers to keep your installation in a straight line form. They won't do that if the tiles aren't square.:)
In fact, spacers can get you into trouble if you don't watch what you are doing.:)
1 - 7 of 7 Posts
