In 2015 I built a barn, 24 ft by 40 ft, on my off-grid property. It's more-or-less pole-building style, my own design. I felled timber on the property, milled all my own lumber, dried it for three years before raising the barn, with sheet metal roof and sheet metal siding. I didn't build doors for the main opening (16 feet wide, 11 feet high). I wasn't worried about security, since you have to come six miles from the main road, the last mile and a half is a rocky farm road, and you have to come through two locked gates. It really is off the grid. I just used a heavy vinyl tarp hung from a cable to close up the opening for the winter.
Recently, however, things have convinced me I need doors. Best would be overlapping sliding doors, but for a variety of reasons, that option is out. So I'm left with swinging doors. The doors will be faced with sheet metal on a strong 2x4 frame with 3'x3' OSB corner gussets on the back (they provides lateral stability and help to alleviate the inevitable droop). From upper inside corner to lower outside corner I'm using a turnbuckle on 5/16" threaded rod, to take up any droop as it develops. Each door will weigh about 250 pounds, give or take 15 pounds. As the green lumber dries out, the weight will reduce, but still....
Every web search I make for heavy-duty barn-door hinges results in dainty designer hardware to hang what decorators call "rustic barn doors" for bedroom closets and living rooms...saints preserve us. I've found a few sites that sell real hinges, but not as big and beefy as what I want. I'm looking for square 6 by 6 butt-hinges, zinc-plated steel, preferably 3/16", but 1/8" would do. Minimum weight rating of at least 300 pounds each.
Does anyone have a good source for the hinges I've described, or something similar?
