Hi all, I'm new here I love trying to teach myself new things and this is my first post on DIY. I am building a swamp cooler as per the instructable
http://www.instructables.com/id/Portable-Evaporative-Cooler-swamp-cooler/
I would like to wire my pump and fan to use in a regular wall outlet, and plan to at some point modify it for solar use. Here's what I got.
A Bilge pump with a 2 amp fuse 12 volt dc with a red and black wire which I assume will need to be soldered to something.
I am also waiting on a 1984 yahama venture radiator fan motor which I believe is also 12 volts.
Here's the question
What is the best, safest, and most efficient way for a DIY beginner to properly wire these two items to plug into a single electrical outlet?
What parts do I need how should they be assembled?
Here's the question
