1 - 8 of 8 Posts
Hi everyone, the special person I had wire my hallway did not do what I asked and instead put 2 lights on the 3-ways. So, what I want to do is wire 3 lights, to the 3-ways and a 4-way. I crudely drew my hallway with switch positions in the picture below. On the 1st switch is a 14-2 power in with a 14-3 out to the 1st light. On the end of the circuit is a 14-3 wire from the 3rd light to the 3-way. From there, I am aware I am going to have to re-wire everything. Everything is open and easy to do right now. Can someone please help me design this circuit so I can operate all 3 lights from any of the 3 positions please? My wires go through the ceiling, and I can use the light boxes as junction points as well.
Super Moderator
Easiest was is power to s1, 14/3 to 4 way switch, 14/3 to next 3 way switch, 14/2 to light one, then light two, then light 3.
Reactions: piscespokerbrat
Super Moderator
You have many options.
The best is power into one switch(3way). 14/3 to switch 2(4way), the 14/3 to switch 3(3way). Then a 14/ from the last switch to light 1 , then light 2 then light 3. The drawing only has one light but just add more in parallel.
You guys are just awesome! I studied diagram after diagram before I found this forum, and I just couldn't get my head wrapped around this. Thank you so much for the help! I now can't wait to finally wrap this hallway up!!!
You guys are so bad ass I swear! I tackled the hallway today.. took me about 2-3 hours, and now I have 3 switches, 3 lights, and I looked the fool running up and down the hallways flipping switches!! THANK YOU SO MUCH FOR THE HELP!!!! Without you, I would have a scared little boy without the much needed lights he needs to get to his room!
Super Moderator
Thanks for letting us know the project worked out for you.
That's what keeps some of us here answering questions.
1 - 8 of 8 Posts
