I need a stiffer flagpole.
I just finished installing a 25 foot sectional flagpole. I carefully dug the hole to size filled with concrete and made sure that the ground sleeve was level and straight up and down. my problem is this.
Once all sections are in place the flagpole just seems a little sloppy and has a slight lean as the pole goes up. It appears to me that the sloppiness in the pole is because of the joints at the sections.
Would it be possible to install a pipe with in the flagpole? Would that work?
I have about 1 1/2 inches of interior room in the sections. What would be Good to use that would make the pole more rigid. PVC ? galvanized steel ?
I appreciate the help
