Our outside basement door is old, doesn't fit very well, and lets air in. Since we don't use it much, I figured it was a good candidate to try a new door seal idea I've had for a while.
I did a test 12" area and it came out great so I think I'm going to do the rest the same.
I'll get pics later, but basically I cut a piece of wax paper and put a crease in it. I taped that on the door edge where normal weatherstripping would be, then in the corner of the door frame I laid a small bead of clear silicone. After a night of having the door shut, I opened the door, removed the wax paper, and I have a perfectly shaped silicone door seal.
I haven't had a lot of luck with weatherstripping doors with any longevity, and with our new/old house needed some solution to work on the old doors. I'm planning on doing the outside basement door first, then the top of basement steps door, then maybe the front as long as it goes well.
