Does it not have a push button on the lower left dashboard to activate and deactivate it?
[/QUOTE Yes, it has a button on the front of the console for that, right in front of the gear shift,,, but it doesn't do anything when I push it, or hold it down. I was hoping that would work, but it didn't.
No, I've tried that. It HAD worked before, to turn the traction on and off, but it didn't work THIS TIME.Chandler may be on to something here. IIRC my Tacoma has a switch that cycles the traction control on and off. maybe you pushed that inadvertently. Worth a try anyway.
I thought of that, at first, since I'd done that before with older vehicles, but this vehicle has so many electronic settings, that I was afraid that a lot of other lights might "pop up".I'd try disconnecting the battery. Leave it off for 5 or 10 minutes then reconnect it and see if the light is reset.
No,,,,,,,,,,,,,no the ABS light is not on. Only light on is the "skid marks".That won't be a problem. At most you'll lose your radio and seat memory settings. One more thought... it might be possible that whilst changing wheels you bumped one or more of the ABS sensor wires. Have a look at those wires and connectors at each wheel. Those signals are critical for the traction control function and it won't work if one is inop. Only thing about that that puzzles me is you should then also get an ABS inop light. I have never had any of these lights in my Tacoma so not 100% which ones you should see.
If you've tried resetting everything, which it sounds like you have, this would be the next thing to check, including checking to see if one of the sensors itself got bumped out of position, so that it's not getting readings.it might be possible that whilst changing wheels you bumped one or more of the ABS sensor wires. Have a look at those wires and connectors at each wheel.
Well,,,,,,,,,I was "out of town" this weekend. Vehicle ran the same as always with the light on,,,,,,,,but, after about 150 miles,,,,,,,,,,the light is still on. But thanks for all the suggestions!Have you rolled the vehicle at all. It may take a few rotations of the wheels to acclimate it to the settings.
DanDIY the zero point calibration reset that i posted is the only way to reset those sensors. It resets the sensors for the traction control system and vehicle stability control system that are causing his light most likely. The system also works with the abs system. The light staying on is a very common issue that happens after having suspension work or in his case having the vehicle up and rotating the tires. Is a very easy reset with a scan tool but you can also do it with paperclips and jumping the pins in the obd connector. Disconnecting the battery, driving backwards, raising truck up and driving with wheels off the ground won't help. It's a calibration issue that can only be fixed by resetting the sensors.Sounds like the light you're referring to is to indicate that you are experiencing poor traction and that the Traction Control system has engaged. On my car that's what it means, and I have a separate light that simply says "TRAC" to indicate that the status of the Traction Control feature, overall.
One other thing you can try is to drive a block with the Traction Control on, and then drive a block with it off. Maybe that would reset it?
Actually i said that wouldn't work. See if autozone or other parts stores have a diagnostic tool or just go to tires plus, Firestone or dealer and perform the reset. If light is on Traction Control should be engaged even in this scenarioOh, and yes, I already tried "blocking up the whole vehicle", and running it and as you said, it didn't work.
