Hello! I had a basement wall reinforced a year ago because it was moving inwards. It moved so much that the i-beam actually punched through the poured concrete wall. The work was done with an engineer’s approval.
Since that time I have noticed that the i-beam moved about an inch length wise. It moved up against the top tread of a staircase and shifted one stringer about 3/4 of an inch from its previous position. The jackpost is tilted a bit but still securely anchored to the i-beam and floor.
The engineer revisited and said it shouldn’t be a concern but I don’t think he noticed that the beam is abutted against the stairs. Should I be concerned enough to have someone professional look at it? I am thinking the stairs are keeping the beam in place so not sure how secure it really is.
