Placing hot water heat behind drywall in ceiling.
Can I use ultralite drywall or will the air in the plaster insulate the heat from getting radiated into the room underneath?
Floor joist/rafter then .5 in OSB then .75 foam board then drywall with screws through the drywall, foam board and into OSB.
If I can use Ultralite drywall, can I use 3/8th in. Ultralite drywall for ceiling?
Thanks
Thanks
