I am looking for some ideas on how to install hydronic heating over an existing concrete basement floor. I am also considering ceramic tile instead of carpet as flooring. The best idea I have had so far is to lay 1" x 3" stringers with the Pex running inbetween them 12" on center. Also installing the metal plates with the pex groove to allow for better heat dissapation. I have a concern though over what kind of flooring I could lay on top of the stringers and still get good heat pass through.
Let me lay it out -
1. Put down a heat reflective barrier on concrete
2. install stringers leaving Pex runs 12" on center
3. install pex and heat dissapating plates
4. Lay Plywood or HardiBacker?? Size unsure ? If you lay 1x3's with tubing 12" on center there would be a 6" gap between stringers.
5. Lay Tile!
After I get the flooring completed I have two options to hook it into my water heating system. I use an outdoor wood boiler which heats the water to 185 degrees and its a closed system. I also use a heat exhanger I plumbed into my hot water heater which works really well. I was thinking the most inexpensive way to add this 440 sq ft room would be to put in a thermostat and zone controlled pump off my hot water heater. If I did this I didn't think I would need the additional pressure tank, etc.
Any information anyone could add would be helpful! I am a Do it Yourself type of guy with no background in construction beside my own home projects.
Let me lay it out -
5. Lay Tile!
