I am using Muralo waterborne in an HVLP for the trim in my house.
When I spray a cased doorway, (3 1/2" casing & between 5" to 8" jamb width) it takes several passes on each side, then straight on for the jamb. (I have also tried doing the jamb first, then the casing.)
Either way, I get some sort of flashing on the jamb. (You have to look just right to see it.)
I bought a little larger needle set to increase the amount of product, but it's still happening, even though the product is wet enough - and if it was any heavier, I'd have sagging issues.
Any ideas?:boat:
Any ideas?:boat:
