I have recently had my Carrier HVAC unit retrofitted with a four zone system. This was to accommodate a new sunroom where I want to control the heat and air more carefully.
One problem: the new system accumulates air (static pressure) in one of the zones that has to be relieved occasionally. When that happens, the system blows/dumps at a really high fan speed for up to ten minutes in one of the zone rooms. The high fan speed is quite annoying and essentially chases you out of that room.
My question is this: is there any way to control this? If it would only blow at a lower speed, everything would be fine.
Thanks for any input.
