My wife and I have been looking at model homes and speaking with home production builders. We are in the market for a new single home. The homes that we have been looking at, and would like to buy one day is about ~5500 square feet of finished living space. It has two floors above ground, and a basement.
We see a split in the middle when it comes to the location of the secondary HVAC system. The primary HVAC system is the same with all builders. The primary HVAC system sits in the basement, and server the main floor and the basement.
As with the secondary HVAC system, some builders put that in the attic. Other builders actually put that system in the basement in the same space as the primary HVAC system. The secondary HVAC system only serve the 2nd floor, where all the bedrooms are.
What are the advantages and disadvantages with having the secondary HVAC system in the attic space?
My best guess is that there would just be less duct work that need to be run. The initial cost (the cost to builder) would be lower. The drawback is that since the system is in the attic, which is an unconditioned space, this is less efficient.
Also, this system cannot have a humidifier. The water line would just freeze during the winter.
What are the advantages and disadvantages with having the secondary HVAC system in the basement?
Since there are more duct work, it would cost more to build. Does it actually cost that much more to have this kind of system vs the one above? It takes up more space because you have a run a giant supply duct to the 2nd floor.
The benefit is that the duct system is inside condition space. Thus this system is more efficient because it doesn't always have to fight against extreme hot and extreme cold. This secondary system can have a humidifier because temperature would never be cold enough for water to freeze.
If my above statements are wrong, please correct me. Please add anything important that I have not mentioned. I'm here to learn.
Greatly appreciate your help.
