Can the drain pan be accessed in a Lennox 80 ugh 4x? I have blown both primary and secondary line but secondary line starts to leak quite a bit after both units have been running for 30 minutes. Thinking something near the outlet in the pan at the primary line is interfering with water evacuating. I poured bleach in the primary "T" and could smell the bleach at the "P" trap in nearest bathroom sink. Also, after cutting PVC (after trap and vent)I could blow back into drain pan. Thinking I should cut PVC near fitting at drain pan and clean with a bottle brush. Also is it typical that both units share the same primary line to sink?
