Apologies if I mix some of the terms up. Electric heat pump/AC.
With heat setting on, when the outside unit kicks on, there are 5-6 loud metal-on-metal bangs. House is maintaining temp and that banging is intermittent.
I took the condenser unit fan off the top and could see the compressor had loosened from the base. I tightened the 4 bolts holding the compressor and that seemed to help - for a bit. Now the banging is back.
Anything else I can easily check?
