So I have a Goodman unit that was installed 2 years ago. Its 90K BTU @ 80% efficiency. I had the guy run 2 additional vents in the basement where the unit is located (now a finished basement), yet these 2 vents put out almost zero airflow. The takeoffs are very close to the Plenum and I'm told that is the issue (the air isn't given a chance to run far enough). Is it safe to assume that if I remove these takeoffs and reseal them then cut in these 2 takeoffs further down the trunk that it will start pumping real air flow?
