Yes, I know that but some frost is normal that's why they defrost but how much RH is normal? I know that it will vary but should it be around 25%, 50% or 75%?Cold air holds little moisture. Any humidity in a freezer condenses and shows up as frost.
Personally, I much prefer repair over replace, but I also keep on eye the point of diminishing returns. Maybe it's time to retire that fridge.... The problem fridge is about 35-40 years old ...
This happened before in the summer of 2013 but I missed the fact that the drain hole was missing. During this past summer the bottom of fridge where the drain hole should would fill with water which I had to sponge out. I can't remember if that ceased during the dryer air in the winters since 2013.On a small freezer that has good door seals. There isn't very much moisture in the air, even after opening the door. So very seldom does any moisture need to be drained. It usually freezes on the product packages in the freezer after a defrost cycle.
From what you and "beenthere" have stated, all might be normal for this time of the year. I just dropped my logging device off for my bro-in-law to log their fridge so I'll get the results in a day or two and compare.Wait until summer.
While the RH (relative humidity) of the air as it passes through active cooling coils can go to 100% (temperature around 0F), the RH drops for the air circulated into the main compartment (temperature around 35F). In winter the RH inside may be low enough that the amount of frost accumulating on the coils evaporates completely during the defrost cycle.
When warmer air enters the freezer compartment, either through the open door or during the defrost cycle, the items in the freezer will exude cold (or suck heat) possibly causing frost to form on the packages. In some cases the surface of the food thaws (and then refreezes after the defrost cycle) and after repeated cycles this can deteriorate the quality of the food.
Would you care to explain what that is?Could be the door/shutter to for the fridge opening and closing to keep the fridge at temp.
If it does and it's moving, it's constantly and seems rather dumb. You have any idea what the point of it is?
My fridge has three large rectangular openings hear the door that connect the freezer to the other compartment. In fact, when it starts to drip, that's where moisture forms.
EDIT:
Looked that up. I assume that the freezer is cooled and some cooled air is diverted to the fresh food compartment by the shutter. This makes sense but constant movement doesn't.
That's a Frigidaire FRS26ZGE which I can't find anything about. I had a new Frigidaire in mind and in all of its documentation makes no mention of a shutter, etc. Since that Frigidaire FRS26ZGE is a bit old itself maybe a shutter wasn't used back then either. I'm just curious which comes from my background in maintenance.You may or may not have a shutter that moves. You'll have to double check that.
Shutter would close so that the fridge doesn't become freezer.
