The humidity levels in my home are an absolute mess!!!
Our home is located in ny and we have a two story house with a finished basement. The house is 30x50 and the ac is separated in two zones - no ac in the basement. Our air handlers are in the attic. Our heating is mostly hot water baseboard - although we are converting some rooms to radiant.
The problem is our house gets very dry in the winter and extremely humid in the summer. Right now our humidity levels are around 75% and in the winter we are usually around 25%. Last winter we had an aprilaire Bypass humidifier installed in our attic on our air handler that handles the top floor. A hot water line was run into the attic and I basically had the fan run constantly. Problem is the pads in the humidifier went bad very fast - weeks - because there was no hot air to dry out the pads. Also - I hate having a water line in my attic. The humidity level did come up a little but I fel the system was working very hard for such a small gain.
So bottom line - is there anything I can do here? I contacted the company that makes that wave ventilation unit to see if that might do something. Besides that I am at a loss.
