1 - 8 of 8 Posts
Administrator
Some commercial apps.
I have them as primary. Because they bring on the A/C and a 5KW heater, to keep the humidity down.
Depends what you want to do.
the house is residential with central air and heat unit.
i want the house to cool or heat when the humidistat is satisfied.
i am in the process of changing my manual heat cool thermostat to an auto heat cool.
can you explain the proper sequense of operation ?
the house is in florida and will be empty for long periods of time in the summer.
Administrator
Will the humidistat only control a dehumidifier, or will it control other devices.
Or will it bring on the A/C to dehumidify.
Administrator
You can do it a couple ways.
One way.
Just wire the dehumidistat parrallel with the thermostat.
That wat, either one can bring on the A/C.
But it may over cool on rainy days.
Plus, you can't have the thermostat set to auto change over, or it would damage the A/C.
Next way. Is to add a lockout relay. That if the thermostat calls for heat, it shuts off he A/C.
And brings on the heat. After the heat is back up. if the humidity is still high, the A/C will run again.
May I ask, if you considered getting a thermostat that does cool to dehumidify automatically.
1 - 8 of 8 Posts
