1 - 20 of 31 Posts
HELP???
SO Last year I had major Ice Damns with all that snow, the roof leaked and mold was discovered in teh crawl space on the front roof slop of my cap code style house. Due to improper instalation of insulation. Had the mold remediated, and had severl contractors with different opinions on how to re-insulate and ventilate the crawl space and the small attic above.
Went with a cotractor who installed Spray Foam insualtion in the soffit and up the roof deck on the front of teh entire house to "seal the area like an envelop". He felt this was the best option as part of the wall had built ins and this way he couls insulate behond it. He also installed soffit vents along back side of the house for ventilation.
Fast forward one year.... New mold was discovered in the attic area, most likely the emergency/mold company failed to notce that the roof leak also affected this area, the moisture remained and now new mold. They say the have to remediate mold, and remove 2 the feet celulose insulation. OK
Now During the same week, we got our first substantial snowfall. I am watching the snow melt from the top of my roof line right up to where the end of the foam insualtion ends. Obviously this is going to create a new ice damn at that point which is well above the water and ice barrier. The contractor said he did nothing wrong, The house has heat leakage in th attic that needs to be addressed. I now know we should have went with soffit and baffle vents and only insulated the interior walls, but now it is too late... It would be near impossile to remove the spray insualtion.
Does anyone have ANY ideas on what I should do when they put this all back togehter? I need to get that attic area ventilated and cold on the front top half of the roof slope.
I'm having a hard time picturing what you trying to expain.
How about a picture.
Is this living space or just an attic?
What insulation type, and how thick is it behind the knee walls.
What
What's on the back side of the knee walls?
Banned
Ah yes, the classic case of the spray foam cure all.
It is tough to tell what the recommendation would be in this case without a better description of the layout, what was done, and/or some pictures.
If you brought a kneewall into the envelope but eliminated the soffit air to the upper roof, that is a huge mistake. Is that what was done?
more vents
so you think it is feasable to put larger or continuos soffit vents in the back of the house and maybe a larger ridge vent to allow more cold air in and hot air to escape.
Did you see my drawing?
Do you think more vents in the back of the house will create enough air flow to keep the front attic ceiling cold?
Since I can not undo what was done, would you consider removing all of the insulation and spray foaming the entire roof deck? (that is one remedy someone has suggested)
Registered User
1. How thick is the SPF?
2. Asphalt shingles? Light or dark color?
3. Is it air sealed under the knee wall?
4. Is there HVAC in attic?
5. Where are you located?
Gary
Discussion Starter · #9 ·
answers to questions from gary
The SPF fills in the joists.
Asphalt dark color
Air sealed under knee wall? Most likely not
No HVAC in attic
I am in Massachusetts
Banned
Asphalt dark color
No HVAC in attic
Not much of this information really makes a difference in this application.
Your :censored: spray foam contractor monkeyed up your roof ventilation and design.
Big N8 is dead on.
Call that joker back and tell him he is on the hook for the roof and leaks.
The spray foam needs to be removed from the soffits and the underside of the roof where it meets the kneewall.
The kneewall should have been foamed as Big N8 says and the joists underneath the kneewall should have been blocker'ed and sealed.
Adding more vents is fine if you want to add them midway up the roof where the roof meets the kneewall with something like a shingle over vent (http://www.airvent.com/homeowner/products/intake-theedge.shtml).
I would tell the contractor he is on the hook and make him fix it.
Discussion Starter · #11 ·
Ugh
The roof hasnt leaked yet, I jsut know it is going to. we had one small snow storm and I could see the potential for the probelm at midway up the roof. Fortunatly the temperatures stayed warm and the snow melted, but I could see how the snow formed little damns already.... I took many pictures.
There is going to be no way to remove the foam unless I take the roof off, given the construction of the house and built ins in the kneww all etc.
The contractor is insisting he did nothing wrong,t here was no way to put in baffles to get the ait from the soffit.
But now he wants to put on a larger ridge vent, and more soffit vents on the back roof to get more air flow. Or remove emerything and do icynene. I dont want him back in my house to be honest with you....
Is that vent you mentionted something that can go under the shingles? Was your thought that I could put it above the foam in the roof line to get the air on that part of the roof and leave the foam?
I have my original roofer coming today so hopefully...
Banned
You don't need to remove all the foam. Just the foam blocking the soffits and the foam blocking the venting from kneewall to the joist bays to the ridge vent.
He would be entirely wrong in this case and that is not in dispute. Any building inspector could draft you a certified letter to that effect. I am not a fan of litigated against anyone but merely getting the letter and presenting him with it, should get you a refund on the work that was already billed.
I don't blame you. Best to sever ties and go on from here.
The vent does go under the shingle and on top of the plywood.
The foam will have to be removed regardless to allow the vents to get air into the joist cavities and to the ridge vent.
Roofer should have some recommendations.
See above....
Discussion Starter · #13 ·
Inspector?
By building inspector, do you mean the town building inspector, or someone who inspects home when youa re sellign them etc?
If I could get that money back, it would at least help reduce the cost of what it is going to take to fix it!
Registered User
Without the questions asked, I couldn’t establish if your SPF could still cause you diffusion problems adding mold to the sheathing for your location by just leaving it in place. According to science, you are fine because of the thickness; see the chart for your Zone 5A- same as Chicago--- if only 2” thick and high indoor humidity- you would be at risk: http://www.buildingscience.com/documents/reports/rr-1001-moisture-safe-unvented-wood-roof-systems
1. Do you know the brand name of the ridge vent, or does your roofer know the NFVA of it? This would tell you if a larger vent is required….
2. Describe the existing soffit venting.
3. He SPF the entire ½ roof (including the slope ceiling) and where is the cellulose with the mold located? In that small knee wall attic? He was correct in SPF of that whole side, so long as the attic air cannot reach the small attic space. Did he block/spray the top edge of the SPF sloped ceiling, air-tight? Is the rest of the attic ventilated enough: http://www.airvent.com/homeowner/products/intakeSoffit-specs.shtml
4. Does the cellulose have attic air above it (vented) everywhere it is installed?
“I am watching the snow melt from the top of my roof line right up to where the end of the foam insualtion ends. Obviously this is going to create a new ice damn at that point which is well above the water and ice barrier. The contractor said he did nothing wrong, The house has heat leakage in th attic that needs to be addressed.”-------
The ice dams/snow melt are from not air sealing the attic floor before installing the existing insulation. http://www.buildingscience.com/documents/digests/bsd-135-ice-dams
For other readers: http://www.wag-aic.org/1999/WAG_99_baker.pdf
“The contractor said he did nothing wrong, The house has heat leakage in th attic that needs to be addressed.”-------
Correct. He did SPF the roof deck to create a “conditioned attic”; Fig.2, see chart: http://www.buildingscience.com/docu.../irc-faq-conditioned-attics?searchterm=attic+
He was right-on with the warning he gave, did you do anything with the air sealing?
Your SPF installation is correct, leave it alone. You need to air-seal under the cellulose to stop the air leaks by chases/elect./plumbing holes vs. diffusion: pp.17 in article: http://www.buildingscience.com/docu...por-retarders/?topic=/doctypes/researchreport
Ideally, you would have discussed air sealing and had him do that as well as under the knee walls with SPF when present; http://www.familyhandyman.com/DIY-P...ency/how-to-seal-attic-air-leaks/Step-By-Step
I can’t stress the importance of air-sealing enough: http://www.greenbuildingadvisor.com/blogs/dept/musings/forget-vapor-diffusion-stop-air-leaks
Have your roofer fix the roof leaks and do a quality inspection of the whole roof, (also check your NFVA), as you learned- any leak on the cellulose from above without enough ventilation will mold.
Gary
If I read right, you've had to demo out the ceiling and attic insulation to remedy mold. Then it sounds like your fix is to continue with the SPF and make the roof line your insulation barrier. Then, when you replace the roof down the road you can place the ventilation space there by way of 2X4 furring strips and an additional layer of plywood. "Hot Roofs" are more common than one thinks and in most manufacturer's cases do not conflict with warranties.
Banned
Hot/Insulated roof design is the way to go at this point if you can afford the expense of the ceiling/roof removal and spray foam.
My only point in this is that your spray foam contractor completely changed the ventilation dynamics of the roof (as I read from your posts) without knowing what he is doing.
While it is frustrating for you, I assure you it is not uncommon.
Are you sure that picture is accurate in its dimensions and representations? Are you sure you don't have a sloped section of roofing that is insulated with fiberglass batts?
Discussion Starter · #18 ·
THe roofing contractor said at this point, it is near impossible to get the spray foam out, and he agrees with a NEW spray foam guy that he works with on remodeling jobs that the only way to fix what has been done is to remove the cellulose on the attic floor, and spray foam the entire roof and make a hot roof. He does not feel that any amount of ventilation coming from the back of the roof will make up for the front top half of the roof not having ventilation.
I have to have the cellulose insulation removed to remedy the mold anyway. The mold was most likely a result of the initial disaster/mold remediation company missing wet cellulose insulation from the roof leak last year. So instead of putting more cellulose in and adding ventilation that may not work, it is probably best to do a hot roof. This is so frustrating, and all the while I have to pray we get NO snow so I dont leak!!!
Everyone thinks that what the original spray foam guy did was completely wrong. Now how do I get the HIM to pony up that he was wrong and totally screwed me and get compensated!
You wont be able to. Simply because the best fix at this point is to leave in place what he did. And if you're going to leave it place, how can it be wrong?
Obviously we know the answer to the last question, just playing devils advocate to give you an idea of what you'll be up against.
Banned
+1
Sucks but 100% correct.
Are you sure about the layout on your drawing? Is there any sloped section of the roofing on the inside surface?
If so, you will need to either drop that drywall or remove that section of the roof to spray foam.
1 - 20 of 31 Posts
