Hi all. Wondering if anyone would like to chip in with an opinion.
I'm installing handrail and iron balusters upstairs. The main issue at the moment is the point where the handrail attaches to the wall (where a rosette would typically be) will intersect with the door casing. I've attached a photo to help explain.
So my options seem to be…
This is all I can imagine at the moment. Any suggestions?
Thanks for any advice!
- Install the rosette and handrail, then trim the casing around the rosette.
- Install the casing, then attach handrail to casing (essentially using the casing as the "rosette," although I don't think it'd be wide enough.
- What was done on the previous wooden setup — the same trim used to cover the 4x4 post was attached to the wall, from the floor as high as the handrail. That was used as the "rosette." The door casing came down until it butted against this trim.
