Our house has a pre-hung, self closing Benchmark metal door and metal frame between our kitchen
and garage. The frame is out of square. It was installed 23+ years ago and has
been that way since we moved in 16 years ago. There is a thick shim behind the uppper
hinge where it attaches to the jamb so that the closed door will clear the top of the
frame on the latch side. I want to try to square up the frame but I need information on how it would
have been installed. I've done much online searching but don't find any examples
of this particular type of frame.
The frame is 3 pieces. Pics 1 and 2 show where the jambs and header join.
I have pulled the vertical wood casing on the garage side a bit away
from the frame and it appears that the exterior of the jamb just bends around
90 degrees (pic 3) and extends 2 inches flat against the drywall, like a flange.
I can also see vertical oval slots each about 1" tall and 1/2" wide spaced every 15 inches from
the bottom of the flange to the top. There is nothing going through any of these
slots but there are what appears to be roofing nails going through the flange along its
length. I assume these nails go into the studs framing the door opening.
On the hinge side of the jamb there are 2 screws through each hinge leaf that
thread into the stud of the door framing (pic4), and on the latch side of the jamb some
phillips head screws that hold the frame to that side (pic5).
The metal frame might be adjustable for wall thickness as indicated by the "lip"
shown in pic 6. The door is in 2 x 6 framing with 1/2 inch sheetrock on sides.
Is anyone familiar with the installation of this type of metal frame, and if so, what is the
correct sequence of nailing it to the wood of the door framing versus shimming the
jambs to plumb them?
Thanks for any insight you can provide!
