Hello,
I am starting to add some florescent lights to my unfinished basement.
i am installing about 8 - 10 fixtures (two 32watt T8 bulbs/fixture)in 4 separate areas of the basement and would like the areas on separate switches. My plan is to do the following:
Use 14/2 600v wire
Install a new 15 amp CB and run a line from it to the 4 gang box
Run a line from each switch to each junction box for each light group
Run a line from each light to the appropriate group junction box and tie all the white / black / and grounds together respectively withing the junction box.
Is this correct?
How do I share the power in the 4 gang box?
In the 4 gang box I plan on tie all the whites together and all the grounds together. If my thinking is correct I can pig tail the black feed to each of the switches.
Is my thinking correct?
Use 14/2 600v wire
Is this correct?
