Hello,
and a big thank you to all of the folks on this forum. Hope you are not going crazy at home.
I would appreciate some advice on how to wire a fan control center to my existing system. Overview:
1. I am installing a booster fan on a long supply run in a newly built section of the house.
2. I already have an armored 12/2 with a receptacle to where the booster fan will be hooked up. There is no power going to this receptacle presently. The fan is a standard plug.
3. The entire second floor is one zone (Zone 1) and the newly built area is another zone (Zone 2). There is no bypass damper as none of the rooms in Zone1 have dampers. Only the newly built Zone 2 has a damper.
4. Using an EcoJay 4x with Ecobee3 thermostats. Zone 1 has its tstat, Zone2 has a tstat with 1 damper. Single speed fan motor in the furnace.
5. I've got a Packard 90113 FCC, with PR340 relay.
6. 120v presently terminates into a 4x4 box installed next to the control board. I call it Power In.
7. From that 4x4 theres is the 12/2 run going to where the fan receptacle is. I call it Power To Fan.
8. The FCC has black and white 20 AWG leads on the bottom, a black, red and brown 16AWG leads coming out of the relay and the RCYGW terminals on the block. C and G are wired to the coil on the relay. Relay black is pin 1, relay red is pin 3 and relay brown is pin 2.
My goal is as follows: Have the booster fan operate only when Zone 2 calls for heat/cool or fan (Ecobee can run fan only to equalize air and I have it running 5min per hour).
I could be totally off, please feel free to correct me. What I "think" needs to happen is this:
Run wires from R, C, and G on the FCC terminal block to zone 2 thermostat terminal on the Ecojay. This way, fan won't operate when zone 1 is calling and zone 2 damper is closed.
Black from Power In wired to black from bottom of FCC.
Black from FCC relay wired to Black from Power To Fan.
Wirenut the whites from Power In, Power To Fan, white on bottom of FCC and the red coming out the FCC relay.
Wirenut the grounds from Power In, Power To Fan and a pigtail that'll be screwed into the metal box.
Cap off the brown.
My understanding is as such. When Zone 2 tstat calls for heat, cool or just fan it'll energize the R, C, and G, thus closing the NO pins 1 and 3 on the 24v relay, thus closing the 120v hot run from Power In to Power To Fan. Once the call is stopped relay is de-energized and pins 1 and 3 return to NO and cut the 120v going to the fan's receptacle.
Does that look/sound okay or do I have it completely wrong?
A big thank you goes out to everyone. Stay home, stay safe (and work on your honey do-s :vs_laugh
Cap off the brown.
