Waterproofing
I have 2 products of choice when it comes to waterproofing walls. The first is Bakor Blueskin - a peel-and-stick self healing membrane available at the Home Depot. Comes in rolls of 3' x 50' and will never fail even if punctured. Google it for more info. My second product of choice is SikaTop Seal 107ca; a flexible, waterproofing and protective slurry mortar. Mix components A and B and paint it on with a mason's brush. Great stuff, if expensive. Check
www.sika.ca for more information. These are commercial products and are sometimes not readily available for the average DIY'er - but with commercial products you will get commercial results........ - care must be taken when using them! Blueskin is tricky to install and Sika 107ca creates fumes. I've used them both alot so if one (or both) of these products fits your needs, contact me and I will write to you the proper installation procedures and well as safety precautions.
