1 - 19 of 19 Posts
· the Musigician
how would i go about doing this area above the 6'x6' windows with this damnable 2x12 perimeter beam overhang to allow proper water flow in the rare event of sideways rain? i have undersill and J-channel to work with,
how would you pro siders do it? is there something more i need to get?
DM
With that extent of siding, you should rent a break if you can't borrow one. Many of the transitions you'll come accross won't have ready made solutions.
Ron
· Home Performance
I'd highly recommend renting a brake---that is, if you know how to use it. If not find, someone who does to help you on your project because that isn't the only place you'll need bent aluminum, otherwise you'll have water issues.
· the Musigician
Discussion Starter · #10 ·
what do you mean? this is the only odd place i need to deal with that i can see. all the rest is windows with built-in J-channels and the doors...?
straight shot all around.
DM
Pro Trim
Check out a product called pro-trim vinyl coil. It can be hand bendable but still a break is eaiser. It sounds like that is what you desire since you do not want aluminum. Have used it once before a couple of years ago for a coastal enviroment. Smaller pieces gave a better appearance over wider pieces. You can get it in a smooth finish or a wood grain.
· Lic. Builder/GC/Remodeler
That area needs to have a section of 1x stock attached to it, prior to installing aluminum over it.
Alternate method: Install a PVC type 1x stock over, like a horizontal corner. Install a drip cap over the top. Install J channel along the edges.
· the Musigician
Discussion Starter · #15 · (Edited)
do you hammer lefty DM? i see your tyvek is upside down like mine is
tom: actually, i hammer with my feet, like all good little monkeys do!
curapa: i'm using pre-shaped aluminum for the fascia boards. couldn't find vinyl.
atlantic: please elucidate. i do not understand the terminology. do you have pics of what i need?
anyone: can't i take strips E or H, (link to pic above) and trim off what i don't need to wrap around the edge with a fine-tooth blade on my table saw?
i'm also considering a 2 or 3 ft. overhanging, shingled awning to keep water away from the picture windows. maybe even all the way across the whole front of that area! that should end my problem by completely covering that whole section...any suggestions? reasons why not? code as to how it needs to be built/attached?
DM
DM
I use the brake for fascia and rake boards and odd places like the one you have. The difference is, I have one and it's easier for me to use it then adjusting premade to have it fit in or carrying an odd sortment of vinyl parts.
If I didn't have one or didn't want to rent one for that small a section. I'd be doing the same as you. Innovative parts adjustment.
Ron
· the Musigician
Discussion Starter · #19 · (Edited)
? i'm not cutting anything down.
the exposed fascia shown will be done in the same pre-made 6" i have on the side.
i'm thinking now perhaps the best way to deal with it is to build a shingled, 3 foot awning over the entire front and flush that with the bottom of the overhang. then i can use J-channel to hold soffit strips. then just butt them up to each other.
permit adjustment needed to add the awning, guys? it'd be lag screwed to the 2x12 perimeter beams so it'd be sturdy enough. anyone?
DM
1 - 19 of 19 Posts
