Hello everyone. I am building a room in my attic. My original plan was to build a wall next to the exisiting wall and have 4 independent walls. Now I am thinking I could just use the exisiting wall. How do I tie in a top plate in the exisiting wall for the ceiling joists to sit on? The wall itself is plenty high 20' plus at its peak and 10' at the bottom. Can I nail a 2x4 flat to the exisitng studs and put another 2x4 on top for the shelf for the joists to sit on. How would I tie in the new walls to the old wall? Thanks for the help!
Post a picture of the room.
A few things to concider when converting an attic.
The spacing and width of the floor joist, most attice were not built to be living space and may cause cracks or sagging in the ceiling below.
There has to be a legal sized point of egress.
How are you going to insulate it. Often times you have to add spacing to the rafters to allow enough room for the insulation and baffles.
How are you going to get the heat and wiring up there.
http://www.energystar.gov/index.cfm?c=home_sealing.hm_improvement_insulation_table
